20" rim with 135mm OLD hub
chrisblessing
Greetings,
I wonder if there exists a 20"/406 rim with a 135mm OLD hub for the rear of a converted 20" bicycle. I didn't use the supplied axle on a front wheel, opting instead to use a spare rear wheel with freehub and no cluster. What I'd really like is a 36 spoke, un-dished 135mm OLD with a thru axle. Practically, I'd have a stronger wheel, aesthetically I'd have a wheel that matches my front 36 spoke wheel (with Nuvinci N360).
I've searched for this extensively but can't find a thing.
Many thanks,
Chris
Your best solution might be to have one built...
Chris,
That way you can match your Nuvinci wheel and get exactly what you want...
Doug
chrisblessing
Thanks Doug
I actually wrote Utah Trikes where I had the Nuvinci wheelset built, but their customer service is a bit erratic. I might call.
Chris
baov
I threw the idea up in
I threw the idea up in another thread about using a fatbike hub, it's 135mm. Don't know if it works, you might want to try and let the community know.
