Oh thanks, the juintech fit huh?Juin tech brakes are a good hybrid option imo. Shimano 105 would be a solid replacement for your front and read mech.
For me..2017 S40. Front derailleur finicky to adjust. Need to have 52t to work (or it's just me). TRP Spyre disc brakes seem ok once adjusted. I tried HY/RD which has self adjusting pad clearance. I never could get it not to have a little disc rub noise. Maybe it doesn't matter, but I switched back to Spyre because I was annoyed.Just out of curiosity, what makes the OEM brakes and derailleur finicky? Since I’m considering a used S40, any insight will be appreciated. I’ve had several disc brake bikes and never experienced anything that caused concern.
I plan on a 1x so that eliminates the front der but yes, slight brake rub can be annoying but I’ve been fortunate enough not to have had much of that over the years.For me..2017 S40. Front derailleur finicky to adjust. Need to have 52t to work (or it's just me). TRP Spyre disc brakes seem ok once adjusted. I tried HY/RD which has self adjusting pad clearance. I never could get it not to have a little disc rub noise. Maybe it doesn't matter, but I switched back to Spyre because I was annoyed.
