Adjustable Stem
Hello,
I got my sofrider assembled in a couple hours and managed to get about 10 miles in this afternoon (after fred flinstoning and learning to pedal this morning). So far, so good.
My knees are a little closer than I'd like to the handlebars which are a little closer to my chest than I'd like. Would this Adjustable stem work on the Sofrider?
http://www.amazon.com/Kalloy-Adjustable-31-8-30-150d-Threadless/dp/B001CK0CZA/ref=sr_1_12?s=cycling&ie=UTF8&qid=1329508963&sr=1-12
Thanks,
GregFork
hi charles,
try turning the
hi charles,
try turning the handlebars around my give you enough room, i did it helped but i think i my need more.
Greg
Hi Greg,
I thought of that,
Hi Greg,
I thought of that, but the handle bars feel like they're too close already.
Or, move you seat mount
Or, move you seat mount forward. This is the special bracket under the seat pan, it can move forward on the frame.
That will help the knees (and
That will help the knees (and I was thinking of trying that), but that will also make the handlebars closer which I don't want.
Will the stem I posted above fit on the Sofrider? thanks!
If it has hte usual 28.6
If it has hte usual 28.6 steerer clamp ID and 25.4 handlebar clamp ID (Internal diameter), then yes, it will fit.
