GuytonMike
What are the things I can do to improve the aerodynamics on my new V20c? I recently added the curved slider and really like it. So all suggestions are appreciated!
and put on a motorcycle sportbike seat bag. When light touring it provides 14-16L of storage space in an aerodynamic package.
It's not the exact one Jeffers, but very similar. That one would work just as well me thinks. Just gotta make sure that whatever straps is has on bottom will work with the mounting system you'll use so it doesn't slip off. Mine never did, but I slid 10" sections of bike tubes onto the aero bars for a bit of extra friction for the straps to bite on.Brillant!
Is this the tail bag you got?
Wheels with deep section rims and bladed spokes are the biggest upgrade you can do, assuming your bike didn't come equipped with them.What are the things I can do to improve the aerodynamics on my new V20c? I recently added the curved slider and really like it. So all suggestions are appreciated!
What would you consider to be deep section wheels?Wheels with deep section rims and bladed spokes are the biggest upgrade you can do, assuming your bike didn't come equipped with them.
At least 40mm.What would you consider to be deep section wheels?
I see you have the Moose bag on your bike. Do you think it contributes towards being more aerodynamic?Welcome to the club Mike! Sorting your hydration (bottles behind your head?) or some sort of tail box or Cruzbike's Race Case. I use the Performance Adjustable Head Rest and TT bars as supports for my 2018 V20 and put on a motorcycle sportbike seat bag. When light touring it provides 14-16L of storage space in an aerodynamic package. I could put a hydration bladder with a bite down tube in it, but that proved to be a hassle when getting on or off the bike. Instead, I put my 3L hydration in a light backpack worn backwards on my chest for hands free hydration.
View attachment 18235View attachment 18236
Yeah, I think the Moose bag helps a bit.I see you have the Moose bag on your bike. Do you think it contributes towards being more aerodynamic?
I am a trial and error kind of guy, settling on 60psi front and back for my V20c with 30mm tires. I weigh 130 pounds, so I don't need to inflate quite as high as some people. 55psi felt a little soft. 65psi felt a little lumpy/harsh. I pump up before every ride so that the ride quality is the same each time.Do you use one of the tire pressure calculators such as SILCA?
Hey Mike, fellow N FL V20c owner here. You are going to blow them away at the Senior games once you get completely dialed in, based on what your Strava numbers already look like! BTW, TDF winner Tadej Pogacar uses the Rene Herse tire pressure calculator and runs tubeless 30mm Conti GP 5000 S TR. I’m a TPU guy myself but to each his own! Enjoy the aero build, can’t wait to see how it ends up.I’m moving from a Rans Rifle that can only accommodate 25mm tires to the v20c. I have the pressure in them at 80 psi. The roads here in NE Florida vary from super smooth to pretty bumpy. I currently have 25mm Continental 5000s also at 80psi. I will be ordering a pair of 30mm ones in near future.
Nice choice with the V20c. To improve aerodynamics, tidy up any exposed cables, consider deep section wheels or rear wheel covers, adjust your fit for a more streamlined position, and use aero gear like helmets and tight-fitting clothing. Glad the curved slider is working well for youWhat are the things I can do to improve the aerodynamics on my new V20c? I recently added the curved slider and really like it. So all suggestions are appreciated!
If you’re ambitious, making your own’s an option.This is my first bent that has a handle bar which will accommodate internal routing of cables. Is there a brand or model you recommend? Also, is there a company that sells wheel covers? I’m guessing finding a 100mm axel disc is an issue.
