I’d be surprised if that worked in the real world. Like
@RojoRacing said, you need a LOT more leverage, namely pulling from a distance, and from the side. With that small a moment arm, the spring gets stretched only slightly when the front end is turned. And after a certain amount of turn, you’re not really stretching it any more. Can you walk the bike holding it by the seat back?
The goal is to add little tension for small turns (no effect on steering) but greatly increased tension at large turns.
I made one on my Q559 (now sold) by connecting an old inner tube from the sides of the seat bottom to an eye bolt that extended out back from the fork about 2 inches. That extension increased the moment arm at large rotation, and it worked well for my purpose of not having the fork flop over while walking the bike, lifting it onto a carrier, etc. Moving the pivot point back from the fork also kept the rubber mostly under the seat and not in the way of my feet while getting on and off.
