belt drive for the Vendetta?
pggm
Hi John and all others who love innovative and efficient bicycles,
My name is Peter Moors and I am new on this forum. I live in The Netherlands (Europe) and I drive recumbents since 1997 and the last 3 years I commute on them on a daily basis to my work, which is 30 kilometers per day. Most of the time I use my M5 Lowracer with Tailbag (Lightning is the dealer in the USA), but when the wheather is bad, I take my Fietser.be WAW velomobile. I have a profile on Facebook for those of you who want to see some pictures and more information.
My experience as a commuter with recumbents is that the long chain needs a lot of maintenance. So I was looking for alternative tractions to be used on light and efficient bicyles. I found the Vendetta as one of the most favarouble alternatives because of the short chain.
In the meanwhile the use of belts as replacements of chains has appeared for bicyles. See for instance http://www.carbondrivesystems.com/ My maintenance problem would be solved with a belt. The disadvantage of this system is that you will need an internal-gear hub. Another requirement is that the frame has to have an opening in order to place the belt into his position. As fas as I can see on the photos of the Vendetta, this should be possible.
My question is: would it be possible to build a rideable Vendetta with a belt instead of a chain and a 8-speed Shimano Alfine hub (or other hub) instead of a derailleur?
Thanks and many happy, save and fast cycling miles.
pjotr320
Also my 1st post on this forum and I'm also Dutch ;)
I don't know how the frame of the Vendetta is constructed but...
A FWD 'bent already is really chain friendly as the wheels hardly throw any debris over the drive train. (my experience) So, there actually isn't really the need for an IGH.
Secondly, the Vendetta is meant to be really fast. IGH are far less efficient, thus slower, than a good derailleur system. Except for the good old SA 3AW that is. That one comes pretty close.
Nanda H.
Interesting idea, but the Vendetta is designed to work with road bike components, so unless you know of an IHG with a 130mm spacing it would be a no-go. This could work on a Quest of Sofrider, though not quite as fast or sexy.
WhiteSilvio
pggm wrote: Hi John and all others who love innovative and efficient bicycles,
Snip/ snip
Hi Peter,
I have left a Private Message (PM) for you with regards to your questions and in turn a question from me.
You will need to Login to see (retrieve) the message.
Regards,
John R.
