Tandem frame conversions...
I have been wanting a Cruzbike tandem for some time. We have a Vision R82, but the drivetrain is 10 miles long and pretty inefficient, and the bike is over 9 feet long - I don't have anything that will transport it anymore.
I have considered building a compact Cruzbike tandem, 406 or 451 wheels, where the stoker sits over the back wheel. I received a 9-foot-long piece of 80/20 aluminum extrusion for Christmas (yes, my Christmas presents tend to be a little strange) to build a frame jig for this project.
http://www.8020.net/
The basis of this frame is a BMX bike, where I would cut the bottom bracket area out to use as a "lug set" onto which I would weld longer tubes. The tube angles on a BMX frame seem to be just about right.
What I've learned about converting conventional tandem frames is that the distance between the captain's bottom bracket and the stoker's seat post doesn't allow for a long enough x-seam; generally this dimension is 22 - 24". You quickly reach a point where it's easier to build a frame than hack up an existing tandem.
Addtionally, the captain's seat back needs to be ahead of the stoker's crankset BB center, to allow for stoker knee clearance. The stoker Bb also has to be high enough off the ground to prevent pedal interference when leaning into a turn.
I have also considered using the Zox square tube tandems as a starting point, as they are pretty easy to build, relatively speaking, but fairly industrial in appearance.
Interested in any thoughts anyone has.
Doug
