Gregory Carlsen
I'm looking for some thoughts on how to correct a issue I'm having with my front (drive) wheel on my V20c. NOTE: This is not the stock wheel - that one is working fine.
A little over a month ago a spoke broke on the non drive side of the front wheel while I was moderately accelerating. The spoke broke at the nipple just where the threads start. I replaced the spoke and spent quite a bit of time making sure the spokes were evenly tensioned using a spoke tension gage. Then on Saturday's ride a second spoke broke on the same non-drive side of the wheel. Again with moderate acceleration. This spoke is 90ish degrees from the previously replaced spoke. I'm replacing that spoke but I'm a bit concerned that there is an underlying issue that I need to resolve. I have been kicking around several ideas that might be the issue. I'm also open to other suggestions.
The wheel in question is a HED Ardennes RA Pro disk brake (drive wheel). It is a 24 spoke, double cross, aluminum rim. Rider weight is 205 and bike is pretty much standard weight. The spokes are Sapim Race J-bend double butted 14/15/14.
The rear wheel (non-drive) is also an Ardennes RA Pro disk 24 spoke 2X and I have not experienced any issues with it.
Do any of the ideas below seem like the right course of action.
1) Replace the second broken spoke and see if another breaks and go from there.
2) Replace all of the (12) spokes on the non-drive side of the wheel and see what happens.
3) Change the non drive side to a 3x pattern.
4) The wheel is just not up to the stress I'm putting on it and I need to replace it with a stronger wheel.
5) Something about the wheel seems defective and I should seek to have it replaced under warranty (There is still 4 years on the warranty).
6) Perhaps the spokes should be a bit longer to better engage the nipple. Should the spokes be even or slightly protrude from the outside of the nipple? The two broken spokes end 3 to 4 mm short of the outside of the nipple.
7) Something else?
I appreciate any additional thoughts you may have.
Greg
7) Something else?
Greg
