Calculating Frontal Area and Drag Co-efficient
Jeffrey Ritter
A diamond frame rider turned me onto gribble-a site that allows you to better understand the power required to achieve certain speeds. The link takes you to a calculator that will input variables, including frontal area and drag co-efficient.
I suspect these are only determined in a wind tunnel, but does anyone have any sense of the manner these are calculated for our bikes, rather than just the religion of believing we are more aero. Would be great to have the science and the religion.
https://www.gribble.org/cycling/power_v_speed.html
If I input my body weight (185) and Silvio weight (24.7) and reverse engineer to the power and speed I generate in the Cruzbike TT series on a flat road, I get a value for A of 2.875 and Drag Coefficient of 0.63.
You also look up the Chung method which take many factors into account from actual ride data and spits out a number for you
In reality - the harder you push the faster you go :rolleyes:- I just crack myself up sometimes!!! :p:p:p:p sorry couldn't help myself :rolleyes:
The number is really only worth something to compare yourself from one setup to another to help determine how much faster or slower you would be - wind tunnel is the best and most expensive place to find that out.
Jeffrey Ritter
Larry, you crack ME up too. Love it. And the setup options are exactly where I am headed. Have to have something to play with!
Best,
J
