Climbing
Midnight
I did a test run today on one of our local, tough, steep climbs. Bear in mind it was too hot, and my legs are wasted from riding this week with hard efforts yesterday.
Climb is short about a mile or a little over, averages 10% with portions 15-20%.
I completed 3/4’s of the climb which included 15+% by sitting up climbing to keep
wheel contact. My lowest gearing is 34x34. I bailed out because of being too hot and too lazy to finish the last segment which is a service road with poor pavement.
Wondering, and I believe Larry mentioned at one point, wedge the seat up and the V20 is a S40. You can now climb more aggressive grades.
Has anyone done that and is it worth it?
Any dimensions on what folks have found?
I’m assuming closed cell or mini cell foam is the better product?
Alanczik
Last weekend I climbed up a hill I was avoiding with my v20, and yes I wish I could change the seat angle at a push of a botten, steper angle at climbs, I do remember one dude here did an amazing engineering design for that exactly,
here is the full topic..
Karl42
Here is another solution for a variable seat angle on the V20 that can be adjusted while riding:
This comes from the german recumbent forum: https://www.velomobilforum.de/forum/index.php?threads/sitzverstellung-fuer-cruzbike-v20.63822/
I looked at both solutions posted here in detail, and might attempt to build the second one myself. For now, I can power up shorter hills by sitting up more upright, and this gives me a good core workout. But it is not really sustainable on longer rides or hills, so the variable seat angle would be really helpful there.
Randyc3
@Karl42, do you think Salaam Aleikum would be willing to share his CAD models? Would ask but my german is not so good.
Update-tried my German. Might have a CAD soon.
Karl42
Just got back from a trip. I have been in touch with Salaam Aleikum some time ago, but it now sounds like you have too. He sent me his technical drawings and additional pictures then, and I've just emailed him to ask if I can share them further.
Manufactoring the custom parts for his approach is slightly beyond my capabilities, so if you make any progress with that, I'd be very interested in that too.
Randyc3
Not sure i will be able to develop a kit, but happy to share what I learn in the process. Once i get my seat scanned(adjustable Cruzbike seat) i’ll do some preliminary CAD concepts of both approaches for the climbing seat. Cheers.
Randyc3
Hi,
Still working on the upper seat back model. Scanning did not work as well as I hoped and there are inaccuracies in the model. I plan to use it for concept development.
GetBent
You all are pretty amazing. I just went with smaller chain rings, figuring that once I hit about 30 mph I will be coasting anyway...
I don't exactly have "Tour de France" quality legs.
Randyc3
Hi,
Hi,
Working on the concept now.
-Support brackets will be 4 mm okumee with a layer of carbon fiber on each side.
- locking pins will be 8mm SS
-relief slots will be cut in existing seatback for brackets to move
-moving seat back will have a slight bend, unlike the one shown.
-locking pin mechanism will be attached to exiting seat back.
We’ll see how the CAD updates go.
Thanks again to Salaamaleikum!
Karl42
Hi,
Looks cool. But are you going to put the locking mechanism on top of the existing seat? Won't that raise the lowest position by quite a bit? What I liked about @Salaamaleikum 's approach is that the locking mechanism is under the seat, so the lower position is the same as the original.
Hence I'm also considering cutting the stock seat in half and then joining it with a carbon-kevlar hinge.
Randyc3
Hi, thanks for the comments. Yes, putting all the hardware on top of the original seat would raise seat back angle. Reconsidering now since I do want to preserve the existing aero advantage. Thinking i will use the upper half of the seat as a mould for fiberglass and carbon. Will bond in some balsa wood in the channels for stiffness. Hinge point/cut will be 10-12 inches from bottom of upper half. Will make cutout and routing holes for cable as needed since the seat back will be custom.
Bo6
I would be interested in seeing a picture of the final product as I am getting a V20 frame and would like to start with a more upright seating angle.
