Cruzbike Chris
I rode this bike from June 2012 to July 2014 and put a little over 7000 miles on it. Yes, it is a great ride and comfortable too. Then I found a used Silvio 2 on this forum in July 2014 and the rest is history. I have not ridden this bike since. It has been sitting in the barn wasting away. I have seen numerous folks on here looking for one soooooo, I feel the least I can do is try to see if there is someone LOCALLY (North TX) first. I do not want to ship this thing as it is something you just need to see and test ride before you buy. I built it up myself so I am very proud of it. My kids did help me strip it down right before I got the Silvio and Plasti-Dipped it in black. It does show some wear and tear but I promise everything on it works great and this thing is a perfect trainer for someone wanting a MBB FWD before the take the plunge on a full blown Silvio or Vendetta. I have kept a pretty good log on this thing as you can see below. I started with a 26" setup and moved to 700. Most everything on here was acquired used with the exception of those items noted below. If you have any questions please PM me here. I will check all weekend long and then if it doesn't sell, it will go up on other bike forums. Pictures before build to today (black) can be seen here.
My Cost: $395 Conversion Kit w/Trek Y26 frame $120 Craigslist
First ride June 29, 2012
Bike Weight: 6/11/2014 700x700 35 degree 47.2 lbs
Middle of BB to top of seat 50"
My Xseam: 42"
Seat setup: current 35 degrees/28" off ground
FD: New Shimano Sora FD-3503-B(L) 3 x 9 Speed 34.9 mm band mount
RD: New Shimano Alivio SGS RDM-430 9 Speed Long Cage
Shifter: Shimano Flight Deck 105 ST-5100 brifters
Chain: New SRAM PC 951 + 2 links
Wheels: Used front: FSA RD-88 700
Used rear: Shimano HB-6207 600EX series 1985
OLD:Shimano 26 SBS SUNSERIES 6000 RHYNO LITE DEORE HUB
(Performance Bike-Grapevine)
Tires: Front: 700/23c CST CZAR 120 psi 310g
Rear: 700/25c Freedom Bicycle ThickSlick Urban Armour Casing 65--110 psi 480g
OLD: Panasonic Panaracer 26 X 1.25 Pasela Tour Guard $36.77 each 9/19/3013 BBS
OLD: Kenda Kwest 26 X 1.50 100PSI BBS 9/26/2012 BBS $29.99 each
Tubes:
Old Sunlite 650 X 18-23 (1") $5.99 9/19/2013 BBS
OLD: Sunlite Thorn resistant 26 X 1.50-1.95 BBS
Handlebars: Custom bent road bike drop
Wrap: New Sunlite Cork Handle Bar Tape
Stem: Cruzbike stock 125 mm black
Cassette: New Shimano CS-HG50-9 9 Speed
11 X 34T 11,13,15,17,20,23,26,30,34 358g
Chainring: New FSA Vero Triple 9 Speed Square Taper 165mm 26/39/50.
Gear Inches: 20..1-119.5
New Cables: New Jagwire 5mm Brake Housings
Jagwire 4mm dérailleur
Brakes: New Tektro Mini V 926AL Linear Pull Brake System 161g per wheel
Brake pads: New vid Rim Wrangler 2 Cart
Bottom bracket: New BB-UN55 Steel
Pedals: Just for test rides and will be removed when sold
Accessories:
Custom headrest
Topeak New MTX BeamRack (A-Type) $41
New MTX TrunkBag EX $50
Pletscher ESGE Double Leg Center Kickstand $41
My Xseam: 42"
Tubes:
Accessories:
Custom headrest
