Cruzbike QX100 - $700
franklong
I’m selling a friend's 2015 Cruzbike QX100 recumbent bicycle, a versatile and comfortable ride that has been upgraded with a 1x11 drivetrain for enhanced performance.
Upgrades Include:
* Shimano Deore M5100 Cassette (11-51T)
* Shimano Deore M5100 Rear Derailleur
* Shimano Deore M5100 11-Speed Right Shifter
* Michelin Country Rock Tires 26 x 1.75 Inch
* 40T chainring
The rest of the components:
* Frame: 7005 T6 aluminum alloy folding frame with robust rear suspension
* Front Triangle: Custom designed power triangle with telescoping calibrated inner tube giving a huge 11" adjustment; plus oversize 34.9mm outer tube for additional stiffness, and constructed from quality 7005 T6 aluminum alloy.
* Handlebar: 600mm wide alloy seagull, 65mm rise, 43° down sweep, Alloy anodized black
* Brakes: Avid BB5 mechanical disc brakes mated with Avid levers
* Wheels: 26" Chosen Front Hub: Rear Hub: Chosen alloy hub with sealed bearings, Spokes: 14 gauge stainless steel & brass nipples, 32 count
* RackTime Rack
Condition:
* Overall, the bike is in good shape with only minor cosmetic wear from normal use. I’m the second owner.
* Some light marks on the frame and fork.
* Paint wear where the seat adjusts and some scratches from stem height adjustments (see pictures).
Scott
I have a very similar QX with the original 2x9.
My question: what is the headrest? This is the next mods I was considering.
Nice ride!
Scott
acorn1005
Upgrades Include:
* 40T chainring
* RackTime Rack
Condition:
Where are you located?
