What are the current specs on a complete T50? This is what I found on the web site but I did find some conflicting information. Mostly referring to 8 speed components.
Cassette: 9 speed 11-34
Shifters: 9 speed
Crank: 155 mm with 38T single chain ring
Wheels: 26", hub spacing 100 mm back, 130 mm front
If I get a frame set, should I consider different crank lengths?
Is the frame for disk brakes only? I assume so but was curious.
Thanks, Rick
My $.02 worth.
I am 6'2" and have a 155mm crank, works great. Probably I could live with 150-160mm. So if you buy the stock build, don't plan on changing the crank until you have got a bunch of miles on the bike and can make an informed decision about pro's and con's.
If you get the frame set, then its a little hard to find 2x cranks that are shorter than 165mm but there are several options. Some name brands like Rotor and Cobb offer cranks in this length range. And Bike Smith will shorten some cranks. 1x Cranks are very easy to find shorter, as the BMX crowd use them, and they can be had for under $100. I used a BMX crank, elliptical 1x chain ring, and upgraded BB.
I believe you can use rim brakes on a T50, but I have not done it myself, so check with Cruzbike. It might depend on wheel and tire size.
You can use either the 26 inch, or 650B, or 700C wheels. But the tire size has to be reduced the larger you go. As an example I am running 26 x 1.9 and have room to spare, but a 700 x 28mm is about the limit in that size.
But I would never recommend rim brakes! Go for the disks.
