frankvl
I made some panniers for my cruzbike style bike made from wrecks. The material is the thicker style of coroplast, commonly used for big "for sale" signs. It's held together by zip ties, guy lines and finished off with duct tape. The slightly rounded shape makes it very solid; you can actually sit on it. It's not detachable without taking it apart. It weighs about a kilo or so, maybe less. I also made bottle holders and a quick access holder for my ereader/navigator. It's much more aerodynamic and stable than normal panniers and I can go on steeper roads now with the same weight.
First I wrapped coroplast around the rack, attached the rear panel, folded 2 panels on the sides and then added the panel at the front. On top there are 2 flaps that open up to access the contents; they stick in place under the top of the seat. Once the initial field test is passed, I want to compartmentalize it and have at least another opening on either side to access the stuff on the bottom more easily. Ideally it would have drawers, but I'm afraid I'll have to settle for just a normal opening and stashbags, because I need all the storage I can get for my tour.
My previous version was just a big pannier on one side using pannier clips, but that was sagging a lot under the weight and the stress from crappy mountain roads.
