Easiest way to clean chain?
Scott
What is the easiest way to clean the chain while still on the bike?
My existing chain cleaner (similar to Park Tool CM-5.3 Cyclone Chain Scrubber) doesn't work with the Cruzbike chain angle.
Mostly a rail trail rider but like to keep up on routine maintenance.
Thanks in advance!
Scott
Beano
Spray some degreaser onto a rag, applying light but firm pressure to the chain, run it backwards whilst applying the rag to the chain. Repeat as required.
Afterwards lube the chain and wipe off the excess.
Should include - Once clean then rinse with water to remove any remaining degreaser, dry with clean rag, let dry then new lube.
If you have a bike stand that will hold up the rear wheel high enough that the chain is level to the ground, you can use the chain scrubber without the cleaning fluid leaking out.
A rope (or bunge but they are scary) to a hook on the ceiling will lift the rear of the bike up either by the rear wheel or the top of the seat tube. Depends on what kind of support you have for your front wheel I guess.
Alternatively check out all the chain waxing thread (or ask for simple instructions if you are interested but don't want to wade through the 18 pages) if you ride enough to wear out a chain or if you don't like things to get dirty (you, your car, your clothes, etc.) Chain waxing is not hard - the initial setup takes more time and is a bit more daunting than just squirt more lube on but the result is great - clean, cheap, clean, better lube, clean, clean...
What @benphyr said. I was introduced to the idea by the thread on this forum. I love it because it is clean. No more black gunge. I followed the instructions on the website of Molten Speedwax, but I do not use the substance that they sell. I use candle wax. Get a master link. But Cruzbikes are the only ones where you can do the magic trick of getting a chain off without breaking it.
Candle wax is too brittle, and cracks and flakes off really quickly. So I mixed in a bottle of vaseline, which makes it slightly more buttery.
Beano
Why use water when degreaser is a solvent? It'll evaporate.
Depending on the solvent, the amount of time you let it sit before relubing, etc. You could easily (likely) be contaminating the new lube you are putting on making it much less effective. Many degreasers work by attaching one end of the molecule to the non-polar grease molecules and the other end dissolving in water which is the solvent. This is how soap works. In the case of bike degreaser there are many products and many mixtures to try to get the best, safest, easiest, least messy not infringed on someone else’s rights, ... some food for thought.
HeyMikey
Hitting the Gateway Trail!
I've been using this for the last couple of years and find that it works pretty good. It leaves a wax like film and keeps the chain cleaner for longer periods of time.IMG_0197.JPG
RoliBar
Sorry for the Rez-post, but if I didn't know about this, I'd want to:
Tthere is a non-toxic solvent option made from orange peel essential oil, and it dissolves grease rapidly and effectively as any petroleum product. It's called Citra-Solv, and is sold widely (they sell it at my local grocery stores here in the SF Bay Area). It's not proprietary (It's just Limonene extracted from Orange peel) but it's the only brand I know of here. I use it for literally everything where stripping old oil/grease is required (door hinges, removing label adhesive, preparing a keyhole for lubricant).
As for technique for using it on a chain, this method is simple and works well for me:
[Materials needed: A brush (old toothbrush is OK, but there are better chain-specific products which "cup" the chain), dirty rag, paper towels, oil-proof glove(s)]
-Running along the chain, scrub the chain with the brush, dunking the brush in the orange oil (in a paper cup or small glass jar) to replenish as needed.
-Using the rag in the off-hand with a paper towel on top to both prevent the orange oil spillling, and wipe the chain. Refresh the paper towels as needed.
(Wearing a latex glove, or vinyl, nitrile, or dish glove, on the off-hand.)
Also, I often use orange oil and paper towels to clean a frame up in a jiffy (old chain and axel grease somehow ends up on there and attracts dust and road schmutz). It's faster and safer than water, and leaves it shiny and clean.
One word of warning though: It is a thin solvent with no water tension, so it will seep rapidly, so bare that in mind. It's easy to apply more than is needed, unless you use a bottle with a dropper to apply it (I often use an old essential oil bottle to apply it when I only need a few drops). It can also be diluted and mixed with water (turns the water milky/opaque when you shake it up), and applied with a spray bottle, for cleaning etc.
And as for a natural non-toxic lubricant, I use Jojoba Oil. It's a liquid wax so it never cross-polymerizes the way natural oils do. It's a bit thin for chains by most people's standards, but I don't mind applying more frequently in order to avoid wasting energy on a sticky chain. (Thick chain lube is a little-known cause of efficiency loss - also harder to remove when it's contaminated). But even if you prefer thicker chain lube, or need to use it for climactic reasons (doesn't rain much here), Jojoba is good for bearings, hinges, keyholes, and anywhere you want a joint to move as smoothly as possible.
The absolute best way is to strip it down and wax it! Then just keep re-waxing it until it is no longer usable. You will never have to deal with grease again! There is an entire thread on this forum for waxing, but I have not time to hunt it up. I use Molten Speed Wax, and they have great directions for stripping the chain to start! Highly recommended, and like I said, you will never have to deal with grease again on your chain!
