Flying Dutchman
Hi,
Following the issues with the Microshift rear derailleur (see my other thread), I started looking into replacing the drivetrain with either SRAM GX/NX Eagle or Shimano Deore XT. There I found that to support a 10-tooth cog, both SRAM and Shimano have introduced new freehub driver 'standards', Microspline for Shimano and XD/XDR for SRAM.
Has anybody tried to replace the standard freehub on the standard wheel of the Q45 (with thru-axle) with either the new Shimano or the new SRAM? If so, which make and model freehub did the job?
From the Cruzbike tech specs I found that the hub is a 'Chosen' hub, however trying to find freehub bodies it appears that there are many different versions.
Anybody any luck?
Thanks
Ted
Anybody any luck?
Thanks
Ted
