Gear-inch range on Quest v3
RoyR
Hey...newbie here...considering buying the Quest...
What is the gear-inch range for the Quest version 3, for both wheel sizes? I can't figure it out since I don't know the data on the internal hub's gearing, or how to apply it to the gear calculation. Perhaps someone here has generated an overall gearing table?
I'm concerned about several comments that note that the gearing "may be too high" on the Quest. I'm more interested in the lower gears. And I lean toward the larger wheel size on my potential new Quest.
Once I see the overall gear-inch range, I might also need to ask if Cruzbike offers a smaller chainring in place of the stock 42-tooth eliptical chainring.
Best...
Roy
(currently riding a Trek 7300 and LeMond Versailles)
Use the sheldon brown calculator for the dual drive
Best way is to just calculate at sheldon brown they have a calculation built for the dual drive. A above is the gear inches for both bikes with a high and wide 9speed cassette which I believe what is shipping on the version 3. Either way iris going to be darn close.
we replaced the stock cassette with a 32T and then a 34T SRAM Without problem
