ebonbetta wrote: I got the basic idea that a hardtail version is not going to ride as shock proff as a full suspension. But I only plan to drive in the city and am wondering how that would be. What do you think. I am still considering the Jamis capri.
Do you think the 279 is worth it. What am I gaining over a cheaper/24-Inch Polaris Ranger Dual Suspension as an example ?
Hi ebonetta,
Hardtails work fine; I've built two and I think DefJack has built two also.
The older Jamis Capri should work and convert to 26" wheels if you change the fork and rear brake:
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?ItemID=92472&Type=bike
Isn't the newer Capri 2.4 a 20" bike?
Another good choice is the older Trek MT220 - MarkB built an excellent 650c bike from one of those...
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?ItemID=12896&Type=bike
Similar is the Giant MTX 250
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?ItemID=31405&Type=bike
Also Fuji Blaster Comp:
http://richmond.craigslist.org/bik/1349727029.html
BTW, BikePedia is a great place to survey frames that are frequently availble used. $279 seems a little pricey...
Best,
Doug
