Question: Here are the specs for my Haro Flightline Comp -- can it be converted via the kit? • 6061 aluminum frame with oversized tubing • RockShox Dart 2 100mm travel fork with rebound, preload adjust, and lock out • Shimano SLX Shadow rear derailleur with Deore 9-speed shifters and front derailleur • Truvativ ISO-Flow 3.0 cranks with sealed cartridge BB • Hayes MX4 mechanical disc brakes Frame Flightline 6061 T6 Oversize Aluminum Sizes 14", 16", 18", 20", 22" Frame Shock N/A Fork RockShox Dart 2; 100mm Travel w/ Preload Adjust Headset Ritchey LB Crank Set Truvativ ISO Flow 3.0 22/32/44 Bottom Bracket Truvativ Sealed Cartridge Derailleur Front Shimano Deore Derailleur Rear Shimano SLX Shadow Freewheel SRAM PG950 9-Speed 11-32 Chain Shimano HG53 Pedals ATB Caged; Nylon Body/ Steel Cage Handlebar Pivit alloy riser bar; 25mm rise; 630 width; 31.8 clamp Stem Pivit alloy clamp on 7 Degree; 31.8 clamp Grips Dual Density Derailleur Shifter Shimano Deore Rapid Fire Plus 9-Speed Saddle WTB Speed V Sport SE Seat Post Pivit alloy micro adjust 30.9 Seat Post Clamp Pivit alloy QR Hubset Pivit Disc alloy 9 Speed cassette; 32h QR Rim Weinmann XTB 24 Double Wall w/ Eyelets Spokes Stainless Steel 14g Tires Kenda Komodo2.1" Brakes Hayes MX4 Mechanical Disc w/ 6" Rotors Brake Lever Avid FR5
