Hi, I have a problem and have not been able to ride my bike. I received my bike Friday, April 5. I assembled it and found the headset to be loose. I then followed the supplemnetal instructions. I loosened the the two bolts on the pivot clamp and the pinch bolt on the Diatech ring clamp. I then tapped down the extension tube and made sure there was no gap between the pivot clamp and the Diatech ring clamp. It tightened the headset up, but it is still loose. To loose to ride. Two questions. Do I need to crank the Diatech ring clamp tighter. It is pretty tight now. I don't want to break anything. I also noticed there is a slight gap between the head tube and the Diatech ring. It's less then and 1/8 inch. Could this be the problem? I would appreciate any help concerning this issue.
Thanks,
Tim
Thanks,
Tim
