View attachment 11558 Take pictures of everything together for re-assembly assistance.
View attachment 11557The bolt/screw goes in from the right and the sleeve in from the left if you were to stand behind the bike. (Sorry, I could not figure out how to rotate the picture.)
All threads are common right-hand threaded. Loosen the screw using a long 5mm hex (allen) key from the right I used a T handle one that I bought because I was worried about not getting my regular hex key into the screw far enough. You might need to hold the left side sleeve with another 5mm hex key - that is only to counteract that it could spin when you back out the screw - a regular hex key the long way should be good enough while you unscrew the right side bolt. Remove the screw.
Screw it back in at least one rotation. Wiggle the suspension up and down to ensure that it is not placing any pressure on the sleeve (and/or remove the quick release from the other end of the shock. Fold the seat up = rear swing arm down to give yourself space to work. Hang from ceiling or stand if necessary. Mine held stiff enough to hold itself up without any force on the pivot.
Push the sleeve through. When I replaced the shock several years ago I think I might have used a wooden pencil. Today I used the screw in one rotation and pushed the hex key. Rotating the left side sleeve with the other hex key can help the sleeve slide out. Once the screw bottoms out then remove the screw.
View attachment 11549Then push the sleeve the remainder of the way out. I used a 6mm hex key with a ball end (mine was not stuck at all this time but I think it was more difficult the first time especially since I didn't know what it looked like inside).
Above is what my two chamber Kind Air shock A5 RR1 125mm looks like with the bottom detached.
This is what the bottom of the Air shock I have looks like from the left
Two pictures from the left into the hole that the sleeve goes into.
From right rear - the gap where the shock fits
And from the rear.
Let us know if you need anything else.
