how to attach triangle to headset?
linkable
Hello All,
This is a different conversion than on my fork question.
I am trying to attach the triangle to the headset. On this bike I don't have a zoom clamp and ape hangers. The triangle attachment only loosely fits on the headset. I need headset spacers or something.
I have not yet moved the crankset. After I do so I may find out that I need a longer handlebar stem.
Can anyone tell me how to attach the triangle to the headset?
Thank you.
Jeff
895_30512757e872b4c62586c5298a94b17d
Hello Jeff,
You might find that after you sit on and test for knee clearance that you have a different problem than what you have stated here.
Regards,
John
If I read your question right and see what I think I'm seeing; you need a 1 to 1-1/8" quil stem adapter. The adapter for the front triangle is meant for 1-1/8" forks.
defjack
You need to use the Cruzbike mast and get thread less adapter and a new thread less stem. All the parts in the kit are there for a good reason . The Cruzbike will work a lot better when its put together the right way. Jack
