Iconic Silvio 2.0 for sale
V2 guy
For Sale: Silvio 2.0 Cruzbike
Silvio 2.1 (NOTE: the frame says 2.0, but we call this version of the 2.0 the 2.1 due to the paint scheme and a couple of small improvements over the original 2.0)
This Silvio has been MODIFIED with a Hostel Shoppe seat conversion, Ventisit seat pad, ADEM adjustable neckrest. The ADEM neckrest has also been modified with CURVED ABS pad holder and a Ventisit neckrest pad.. Also included is the original ADEM neckrest pad.
This bike is in Good condition and well maintained. Tires & tubes + chain + brake pads and Bottom Bracket replaced every 3000 miles; last done spring 2024. The bike has never been wrecked, however there are a couple of minor scratches on shifters and small scratch on frame. This bike has averaged 2000 miles over the last 9 years and remains as comfortable today as when I first bought it. Sadly, have to part with it as wife will not allow N+2 in garage.
Components
Brifters:
Sram Apex 10 speed​
Brakes: Sram Apex road caliper Crankset: Apex compact double SHORTENED to 155mm
Chain rings:
Big ring: Roto Q-ring Red 50tooth + Small ring: standard Sram 34-tooth small ring
Cassette: 10 Speed - Shimano XT 11-36 MODIFIED to a 13-42 with a 42 tooth Wolf Components red cog/with a 13tooth locking ring from Absolute Black -
FD: Sram Force 22 Yaw
RD: Sram X9 Type 2 with the locking arm mech.
Chain: KMC X10SL Gold 10 Speed chain (116 links)
Wheels: FSA Vision Team 30 - 20 rear and 24 front spoke count.
Seat: Hostel Shoppe Carbon Comfort seat w/ matching Ventisit seat pad and seat mounts.
Headrest: ADEM neckrest modified with an ABS curved neckrest
Tires: Mr. Tuffy tube protector on both wheels. Goodyear Vector 4 Season 700X28 on front; Continental Gator Hardshell 700X28 on back. Less slippage with Vector on front.
BarTape: 2024
Bag: Bentup Aero Bag, Red
Shock Pump: (Standard Cruzbike). Kindshock slowly loses pressure. I have inserted a rubber collar around fork tube that reduces 25 mm travel to 2mm; this makes for more rigid front fork and improves steering.
Original purchase $3000.00 (2016). See attached photo with bike stand
Present Condition 2025 with underseat bag. New tubes and tires; new wheel bearings; (new chain 2024). See 2nd photo against white wall.
Will deliver for $1200.00 local (Indianapolis or 75 mile radius). Cost ~$200.00 to ship estimate.
Zefal mirrors not included.
Nabs
What is the seat angle after the conversion?
How is the sizing on this model - would it accommodate a 46 x-seam and 215 lbs weight?
V2 guy
The original 2.0 angle was ~ 28 degrees. I think this is closer to 32-34 degrees with conversion. A chainstay extender can be added to accommodate your longer x-seam; the MBB should not be an issue. I run 700X28 tires with 80 psi; would see no problem with weight if you drop to around 70 psi.
GMJ
Hey, will you take 1000.00 and I can pick it up tomorrow. I am about 2 hours south in Ky. I have never been on a recumbent. Trying something new.
V2 guy
Starting on a cruzbike without ever being on a recumbent will be challenging. Can you ride something local first? Don't want you make a trip and decide it's not for you. I will be home tomorrow; knock off $100 for local pickup. Let me know and we can PM as to time and place.
V2 guy
anytime after 10A is fine. There is a good flat trail at 75th street and N College avenue where you can park and ride next to Broad Ripple village, which is a good place for food. I'll have bike there when ETA is close.
