Kind Shock KS A5-RR1 Dual Air Rear Shock 150x30mm, ST1442 on QX100
Scott
Several questions:
  • Will this work on my QX100?
  • Does the extra 25mm cause any issues?
  • The little bit of literature available on this recommends dealer servicing every 25-30 hours of use.
    • Any idea of what this involves?
    • Does anyone have enough usage to share maintenance history?
  • What alternatives are available?
    • Again, personal experience would be appreciated.
Thank you all in advance!
Scott
@superslim or others: Any thoughts on sag between the two sizes on a QX100. And/or effects one would notice because of changes in headset angle/rake/trail?
If you put a smaller wheel or even a smaller tire on the rear you would probably make up the difference in geometry caused by the larger shock.
