What I carry on a Silvio
I have an Old Man Mountain front rack.
I carry a small dry bag with a change of clothes (no shoes) to work to/from each day.
When the weather gets cold - it get's kinda packed but I can smash it down usually enough.
I affix it to the rack with two bungee cords.
I've had two failures; both times when the cords were too loose - wrapped around the axle and broke the cord.
I also occasionally carry my work laptop ~13" Dell as well.
This adds about 6 lbs to my load and is NOTICEABLE.
Both in rear sway and going up hills.
I have in the past used a hard-sided drybox but it was too big and made a ton of noise and blocked too much wind as well - so now it holds stuff in my garage.
I would like:
* A little longer base (the OMMountain rack is a little short).
* A bit easier installation / removal - I'd rather not have to change skewers (long vs short) when I take it on/off.
* A bit easier access to my rear brake with the rack on.
* Something sorta like the Bachetta BrainBox would be pretty awesome - but I like sturdy and so it would have to have some reinforcement to be worth it for me (no idea whether the BrainBox is / is not reinforced).
Lief
