Hi,
I found with the
Hi,
I found with the original gears that were on triple I bought, I was able to alleviate the problem by adjusting the front derailleur. I probably could have made the problem go away with the original double crankset as well with the same method, but I knew I was upgrading to the triple, so I never bothered much.
As far as the tiny granny gear goes, I think you are exactly right. Try the default triple on your hills and if that works for you, then you're golden.
There is also the issue of balance. It can be hard to balance these bikes moving slowly and for some people, they would never get any use out of the very low gears (this is largely a practice thing that could be overcome in most cases, I think). And, of course, you could very easily be in better shape than I am and have an easier time on the hills.
I'm currently vacationing in Vermont at my inlaws and I brought my bike along. There are real hills here. They (unfortuntely for me) live on top of a large hill, so in order to get back home, I have to ride the last two plus miles up hill. The average grade for this part is above 4% with several 8% sections.
With the old setup, I've been able to climb very short, very steep (18% according to my bike computer) hills. But for long, sustained steep sections, I spent a lot of time in my tiny granny yesterday at the end of the ride and I was very glad I had it. For several sections I was averaging under 4.5 mph and my gps track says I hit as low as 3.6 while I was still moving. It also seems to me (but I can imagine that this is just some bias I have) that it is easier to start on big hills with the lower granny.
