Take a look at the different mounting adapters for the magnic lights here:
http://www.magniclight.com/MagnicLight/index.php/en/hikashop-menu-for-categories-listing/category/listing/23-adapter
In this part of their website you can click on the little pictures and get a big one (mostly) to be able to see more detail.
Considering the Cruzbike geometry, where could these be mounted so they would work on a Cruzbike? Primarily on the front. I don't see as much of an issue on the rear.
I can see maybe one front light under the chainstay on the left side about where a combined speed and cadence sensor goes as long as the light didn't stick out too far into your pedal arc. The right side wouldn't work because of the crank and chain assembly in the same region.
