JonB
Hi
I have made a midrack under the seat for my Cruzbike Freerider. Pictures will follow when tomorrow when it is daylight. I spent untold hours talking and thinking about how to make it. I made and mounted the first prototype in 4 hours and 15 minutes. I wasted at least 2 hours making stuff that didnt work in reality.
In the end what worked was a rear triangle made of 3 pieces attached to the tube clamp and a spacer piece between the 2 arms from the tube clamp. All 3 pieces form the rear triangle. 2 arms in front attached to the most forward seat bolt in each side.
The 2 front arms and 2 rear arms are wrapped arround a solid 10 mm round aluminium piece which is bent and shaped like a U. To keep the wrappings secure i have bolted them together with 2 cm extra wrap arround the round solid.
To make the 4 arms i used 2 cm wide, 2 mm thick 20 cm long aluminium which i wrapped arround the solid round 10 mm. The spacer piece is 16? cm of the same 2 cm wide 2 mm thick aluminium.
The luggage carrier part is a 100 cm long 10 mm thick round solid aluminium piece. I only made it 100 cm, bent arround the middle, about 10 cm used for the rounding, meaning 45 cm for each side for panniers. This piece could possibly be 10-15 cm longer on each side further extending the rack onto the sides of the rear wheel.
