Nut/bolt questions for Silvio 2.0
unc99
I'm struggling a bit with which bolts to use in certain spots on the new Silvio 2.0. In particular, I'm not sure which nut/bolt combination to use in the boom clamp that connections to the fork steer clamp (see attached pictures). If there is someone that can give me some guidance on the combination to use from the attached picture it would be much appreciated. Also, to the extent the answer does not involve items 2,3,4,5 where are these items used?
Oh dear.
1 and 6 are for the
Oh dear.
1 and 6 are for the chainstays, should be 8 pairs. You would also have 16 washers for these.
2 and 3 are for the slider clamp you have pictured, 2 has a lug not shown that fits a key slot in the slider clamp as Jeremy observed. There is only one pair like this.
4 and 5 appear to be M6 sleeve nuts, one of which would be used to attach the front brake.
We didn't actually ship them to you loose in one bag, did we? ;)
The clamp should have a notch
The clamp should have a notch next the bolt hole on one side. I'm not sure from your picture, but find the bolt head with a feature to match the notch, then mate it with the other part that gives the right length for the clamp.
I doubt these crappy photos will help, but here is the side with the notch, note the round hole in the bolt:
IMG_5629.jpg  width:619px
The other side has a bolt with a hex head (and a washer):
Sorry I can't be more helpful without disassembling mine.
unc99
Thanks guys...that answered
Thanks guys...that answered my question. Hadn't noticed that slot for the boom clamp but that makes it clear which nut to use.
