mickjordan
This may seem a strange question but here goes anyway. Is a goal of the CZ Xen master to (a) steer with the feet or (b) not steer with the feet.
I ask because when you are learning, steering with your feet inadvertently is what makes a CZ seem so tricky. Once you learn to balance the bike and pedal good circles, the bike stays balanced until you do something with your feet that again invokes pedal steer. For example, one of my scary moments was rotating my feet through 180 backwards while coasting down a descent, something you do without thinking on a DF bike. I nearly lost it because of the accidental pedal steer.
So one view would be that you need stable feet without steer and all steering should be induced by the bars and/or body lean. The other view would be that you get so good at pedal steer that you can turn corners without the hands on the bars. I would hope its the latter, but this is evidently something that takes a lot of time, whereas no hands riding on a DF bike is something a novice can do quite quickly since it only requires body balance.
