Frank Costantini
I noticed that when I shake my T50 laterally (holding by the handlebars), something in the frame is loose, and I can see some slight movement where the steerer tube enters the frame (underneath several spacers - see red arrow in first photo).
The allen bolt at the top of the steerer tube is already very tight, and I didn't try to tighten it any further.
There are three spacers underneath where the boom attaches to the steerer tube.
The top one (labeled Problem Solvers) is tight, and when I loosened the Allen nut holding it, it would rotate but not move up or down.
The two lower spacers can both rotate freely, and there is no apparent way to tighten them.
Lower down, there is a gap of about 2mm between the fork and the frame ( green arrow in second photo)
Is this something easy to fix, or should I take it to the LBS?
Frank
Frank
