I had to hack up my
I had to hack up my conversion kit for the same reason. I'm 6'3" tall and the cranks were way too low.
Here's what I did:
#1 - cut the tube in half (I think it's called the chain stay?)
#2 - inserted an alumnum tube *inside*. The tube was covered with gorilla glue. From what I've found, Gorilla Glue is as suitable for bonding aluminum to aluminum as epoxy is
The pic above shows what it looks like. The bike is still a 'work in progress'
If you decide to do the same thing that I did, here's a few tips:
#1 - get a pipe cutter from the hardware store. It eats through the tubes and makes a nice clean cut. Don't bother using a saw, a pipe cutter does it better
#2 - use an aluminum tube that will 'sleeve' the whole length of the chain stay. It's stronger and it creates a long surface for the glue to bond to
#3 - speaking of glue, use plenty of it. One one of the chain stays I didn't use much Gorilla Glue, and the joint slipped. Since the whole tube is sleeved, when the joint slipped it was unventful, it's not like I crashed or anything.
#4 - I reinforced the sleeve by inserting dowels perpendicular to the chain stay. Basically I drilled holes perpendicular to the chain stay, inserted a dowel covered in gorilla glue, and then wrapped the whole thing in electrical tape to keep the glue inside the joint while it dried
MAKE REAL SURE YOU MEASURE BOTH SIDES. If one side is longer than the other by even a centimeter, the wheel won't 'track' straight, and the crank will be canted to one side.
Of course, since I'm very sloppy, this is exactly what happened to me
And as always, never take any advice from a Cruzbike rider whose bike is nicknamed 'the deathtrap'
