Has anyone setup their Q45 with the Wahoo Snap? If so, how? I want to stay "wheel on" here in Colorado Springs as we occasionally get some good days in the winter and I don't want to mess with reinstalling the wheel every time I want to get a quick ride in. Thanks
I use a 2019-S40 with a wheel-on trainer ( A Kickr Snap motor attached to a modified Cyclops trainer frame !
.. long story).
I think the Q45 frontend is identical to an S40. So I believe it should work.
The tyre, ideally, should be smooth with no treads otherwise it's going to be a noisy experience.
Question is, does your Q45 have a quick release or a through axle?
If it has quick release then you just need to install a heavy duty steel skewer and it should work.
For through axle, you will need a special through axle that allows you to clamp to the trainer. I think wahoo sells one.
@Robert Holler can advice you on the correct thread pitch among the ones shown below.
https://www.wahoofitness.com/devices/indoor-cycling/parts-components/kickr-snap-142-adapter-buy
Below is my S40 on my clandestine KickR-SNap
