Question on geometry and balance on the v20
shnibbles
Has anyone here every tried riding the v20 in prone position with your legs going out amd around the back of the seat so you are pretty horizontal and then pedaling with your arms? never ridden a v20 and i cant do this on a more upright recumbent. want to know because it would give my legs a nice rest
Henri
scatter brain
Sorry, to be so blunt, but while I am not completely sure what you are saying, I am fairly certain that it's nonsense. You want to turn yourself around, head down and hands on the pedals!?
- There's no space for your head.
- Trying to see forward from tilted down so far will quickly damage your neck.
- Legs are longer than arms, you won't reach the pedals. (Unless your proportions are highly unconventional.)
- I assume, even if you had somewhere to put your feet for more comfort and stability, balance would be horrible.
If your legs need a rest, ride more gentle or get off the bike instead or injuring yourself with such an idea.
shnibbles
hips over the bars sir
Henri
scatter brain
Oh, okay. Might be a bit more "comfortable", but also more unstable and hard to control. Your center of mass way high right on top if the front wheel. Lots of steering inertia, as you have to move your whole body together with the front if the bike. Your legs do the steering at the back, which feels very unintuitive.
On a stable trike where you can think about steering, it probably would work, but balancing a bike sounds scary. If you're goint to try it, please be prepared to fall immediately and to fall often. (I am not trying to imagine, how a fall would play out. Maybe it's a gentle landing on all fours, maybe you poke your waist with the brifter and your thigh with the end of the bar. With sufficient impact/weight the force of that last scenario could do some real damage. Please be prepared and don't be alone in case of injury.)
IyhelM
There was a guy at the Worlds in Austria 2 years ago on a low racer with a similar position. It did not look very comfortable from a breathing perspective and knees were spinning far too close to the ground to my liking.IMG_0445.jpeg
Screenshots from @markciccio ’s video of the event.
