Stock QX100
modified X
So here is the prototype steering mod on my X100 (i also have been riding a Quest for 14 months with mileage at about 8500 miles mainly commuting to work about 20 miles daily) in my continuing experimentation to see how I want to customize my ride. I have two similar Cruzbikers, a Quest 3 and a Quest QX100, so that I can ride to work on one and experiment on the other. I try to keep the Quest stock since I have found that when I teach others to ride the stock seems to be best. So why am I experimenting if the stock is best? Because trying something that may be better is why I tried my first Cruzbike and that was a winner so why stop now?
So the first pic is my stock X, and the second is my current config (not the final config I think). Then there is a close-up of the mod, and then a side view.
Basically I wanted to get this going, and document where I am before continuing.
It took a long time to sand the new slider tube so that it could fit into the stock boom. I blame whoever in the US who kept us from converting to the metric system (my thoughts only) because I like a good citizen ordered the tube using good ol' English measurements (but now my thinking 'stupid me' since the English were smart enough to switch to metric! So it took me a long time and many blisters to sand by hand the tube to fit into the boom, not to mention the pile of wore out sandpaper. Is that recyclable? I am thinking that there is still some sanding to go because I will need to treat the aluminum somehow so that it does not corode together with the boom in the long run. Paint? Anodize (whatever that is), or oil?
So today I stuck the new slider into the boom, clamped down the quick release, set and screwed tight the RD cable housing clamp thing that also helps clamp down the slider tube (if you did not know this this would be an extra step when making adjustments to slider tube - for me that is why I keep my Quest stock for introducing others to Cruzbikers).
Then the spacers added to the fork riser tube, and a different clamp than I thought I would use but came in handy from my odds n ends box. The tube clamp needed a shim - I used a piece cut from a plumbing rubber connector. Bolt to the clamp. Good to go!
Sort of, as the handlebar stem needed to be put on backwards to fit the new slider, and I needed to shim the handlebar into the stem. What to use? Hey I had to do it, as it was the only aluminum can in this place! And so not to waste the innards of the can I drank it all. Quite fast as I recall so that I could get this job done. (The job at the time on my mind was I had to drink so that I could continue with the investigation). I cut up the Fosters can to use as the shim - it sacrificed all!
