fatall
OK, I've had a problems with the rear brakes, when I was stationery and on a slight hill I would use the rear brakes to keep still, but on the Quest the bike would still roll, the brake lever was ok, but it just would not hold the bike on a hill.
So I had some BB7's sitting at home and I decided to swap both front and rear calipers to BB7's. The rear brakes are now very good...maybe to good, it is very easy to lock them up.
Which leads me to the second question about seat angle, because the rear brakes are easy to lock up, I am thinking there is a weight bias over the front wheel.
If I was to adjust the bracket(in the green circle) to the middle hole would this ease/solve the rear brake lockup?
I will most likely do this anyway, but I want to see if this is a problem others have had and did they solve it the same way?
