I am having some minor knee pain on longer (60 km) rides and plan to change my stock Q45 crank set to a Rotor to get shorter cranks and try a Q ring. Hope this helps the Knee problem and helps me smoothly spin at a higher rpm. I plan to try a 40 tooth chainring vs the 42 standard one as I anticipate the 150 cranks will make it a bit harder to climb hills.
Will a 40 tooth Q ring be similar gearing to a 40 tooth round ring? Is the 2 teeth drop enough to compensate for the shorter cranks (I do not want to lose too much top end)? Are 150 cranks too short?
I welcome thoughts and comments from those who have made this kind of change.
