Anybody tried one of these: https://www.rudyprojectna.com/products/the-wing?variant=31503717433409
Can you fit prescription glasses behind the lens ? They say you can ?? My Giro air attack I cant.https://victgoal.com/collections/bi...-goggles-road-bike-helmet-with-usb-rear-light
This Victogal is a gem on the V could use another mm or 2 on the shield bottom but I’ve been using it for a while and I love it. The shield is subject to scratching but replacements are cheap
I had looked into them a long time ago but discounted them due to the weight and also that they don't appear to be designed with keeping someone cool in mind. They have to be so much more stout that cycling helmet for obvious reasons and the runs are so short (and it is cold) that they probably don't have to worry about ventilation either. You might bake in it is you rode around with one for a hour.How about a luge helmet?
I am sure I could make the holes bigger with a file.
Or maybe having a bicycle helmet manufacturer make some shaped like luge. (The flip side idea - changing the shape might be easier than adding ventilation to something that they are not used to considering ventilation.)I had looked into them a long time ago but discounted them due to the weight and also that they don't appear to be designed with keeping someone cool in mind. They have to be so much more stout that cycling helmet for obvious reasons and the runs are so short (and it is cold) that they probably don't have to worry about ventilation either. You might bake in it is you rode around with one for a hour.
But, the design is pretty much what we (recumbent riders) are looking for. Might be worth looking into, maybe even contacting a producer to see if they would be willing to produce a recumbent version![]()
