Scottish Borders / North Northumberland
Niall
Any Cruzbike owners in the Scottish Borders/North Northumberland area?
I'm really interested in seeing an S40 and to talk to an owner about their experience with the bike.
Flying Dutchman
I'm in Harrogate - North Yorkshire so a bit further south. I have a Q45 and done some 500 miles with it so far. Will be doing the Coast 2 Coast on it finishing in Tynemouth first week of August so that would be a bit closer to you
Niall
Hi Flying Dutchman,
Thats a nice route with a few wee climbs - it’ll be a good test of the bike (and the legs). If you’re taking the route through Hexham I could pop down on my bike and meet you for coffee and a blether perhaps?
I’m really keen to hear your thoughts on how the Cruzbike copes with UK conditions. I think we may have more potholes, wet roads, traffic and possibly sharper climbs than the home of Cruzbike (though to be fair I’ve never been to Massachusetts, I’m basing my comment on what I see in their promo images).
I’ve had a few recumbents and am aware of some of the issues so I’d value your experiences of how your Cruzbike copes with:
  1. Starting off - getting your feet up and into the cleats on anything other than flat smooth road is a bit stressful
  2. T-junctions - being feet first it can be tricky to see up the road before pulling out
  3. Neck pain - I’m thinking your Q45 is a bit more upright so this is less of a problem?
  4. ”head wobble” - I cant think how else to describe it, but when on the usual rough bumpy surface of uk roads the bumpy jarring makes it uncomfortable on the head and makes vision a wee bit blurry.
  5. Hill climbing - do Cruzbike really climb as well as they say?
  6. Front wheel slip - have you experienced this? We have wet, steep hills, often with a bit of gravel. How does cruzbike cope with this?
  7. Shin strike - some of the previous recumbents I’ve had have had a problem with the shins sticking the handlebars on anything other than a straight road.
My email address is Niall.OBrian@icloud.com if you’d prefer to email me than do a public post.
Many thanks
Niall
Flying Dutchman
Hi Niall,
We won't be going that far north. We'll be coming in from Stanhope - Consett - Whickham. Happy to meet for a coffee at any of those places.
The Q45 is very happy on the UK roads. The original 650 wheels have 42mm tires which can take on any reasonable gravel routes like disused railways and canal paths.
I've just changed these to significantly faster 700 gravel wheels with 35mm tubeless tires. They are still happy with potholes, much happier than the standard road bikes that's for sure :)
The standard Microshift derailleur is ok-ish and with the standard chainring/cassette gives you a lowest gear of 42/42 so 1/1 which can take on most reasonable hills. However for the C2C I decided that I wanted more range so I changed into a 12-speed SRAM 10-50 cassette and SRAM GX Eagle derailleur. Shifting is a significant improvement and of course more range at either end.
Re your points, very valid:
1. I've not tried clipless yet, starting off might actually be easier with clipless as you clip in one shoe and can do full turns with a single leg, then once going, clip the other leg in (see some of the videos of the Florida gettogether). I've not done clipless as I want to do the C2C with normal shoes.
2. Looking over your shoulder is indeed different so if the t-junction isn't a straight angle but say 45 degrees coming from the right (the driving side here in the UK), it is difficult to see so in those cases I stop properly and look before joining the road. Also, on DF bikes I've never considered a rearview mirror, but on the CB I have one and use it a lot.
3. Neck pain - absolutely none whatso-ever. I have my seat quite far reclined so probably similar to the S40 and my neck is in a normal position as opposed to the stretching back position you would have on a DF.
4. The Q45 has rear suspension :) Super comfortable.
5. Here in Yorkshire we have some short very steep climbs (15 - 20%) which I happily do on the Q45, especially with the new gearing that I put on. On one of those very steep short climbs I posted my second fastest time. My fastest time was when I was 10 years younger :) Also longer climbs are not an issue. I am still slower on those than with my DF but they are totally rideable.
6. Wheel slip, only had that once when on a steep bit of gravel path, a bank to get up to a railway path. Still despite the wheelslip I managed to get up the bank without having to get off.
7. Shins don't get anywhere near the bar on the Q45. Your upper legs might, but then you can just adjust the bar closer to you. I can't imagine this being any different with the S40.
I was seriously debating between the Q45 and the S40 and I'm sure I would have been just as happy with an S40, it's just that I found a nearly new Q45 with the right spec (thru-axels) and numerous accessories here in the UK for a reasonable price. If I'd found a S40 in the same situation, I probably would have ended up with that one.
Hope that helps,
Ted
Niall
Hi Ted,
Many thanks for your detailed reply. I’ve read it through three times now to make sure I didnt miss anything - very useful indeed. Your gear ratios, SRAM Eagle (I love AXS on my mtb), 700c 35 tubeless and much else resonates with what I had in mind as a good setup.
Stanhope - Consett - Whickham is not too far so I’ll send another msg at the end of July to see if we can arrange a meet for a wee chat.
Many thanks for your reply, and have a great C2C adventure
Niall
Niall
Hi Ted,
Hows the plans for your C2C coming on - is the plan still to be heading through Stanhope next week?
