Seatpost help
Biscuit
Hi it has been a while.
My first build was last year with a Wal-Mart Avalon.
Worked real well until a few weeks ago.
During routine maintenance I noticed the rear shock was tweaked and the front suspension seemed to be going. I had an older mountain bike that I put a new fork input have one issue.
The seatpost is a 28.8 and I have not found a straight seatpost that size. I have also looked for a shim, but have come up empty handed so far.
Any suggestions?
Thanks
Rod
Hi Rod,
I think you need the first one on this page...
http://www.jensonusa.com/store/product/SE405C00-Seatpost+Shim+Fits+272Mm+Seatpost.aspx?sc=FRGL
Best,
Doug
Biscuit
Doug,
Thanks. Maybe it is because I'm a bit anal. I did see that, but did not consider it since it was only 28.6 :oops:
Changing the topic..
How would you fix the issue that the tire needs to be raised to properly line up with the brakes? :?:
Move the mounting holes where the forks attach to the offset bracket?
Thanks,
Rod
Rod,
I assume you have the fork turned around 180 degrees, this is required to get the brakes to line up.
Also, you should be placing the wheel axle about mid-way in the axle slot in the triangle brackets, and then using the furthest-forward set of mounting holes that will work.
A photo would help.
Best,
Doug
Biscuit
Doug,
After trying everything I could think of I went into the LBS I had purchased the new forks from and ask the if they had put a fork on for a 29" wheel?
They looked and said that they had.
They would order a new fork, but i asked if we could work out a good price for new wheels and they will since they indicated if was their mistake.
Thanks for all your input Doug.
I will post pictures upon completion of this build.
Should be riding soon.
Rod
