I was thinking that adjusting the rear suspension of Silvio 2.0 would also affect the seat angle. How much would this change the seat angle and would it be significant for those wanting to tweak this angle? Below are my data and measurements.
Conclusion: The seat angle changes from 27.0 to 27.4 to 27.8 deg in the low, medium, and high positions. This range is therefore probably not significant enough for those wanting to adjust the seat angle.
Note: When I was adjusting the disc, I completely removed it so I could see the suspension block. Only did I see that it was "stuck" in the threads. Putting my full weight on the frame resulted in one side of the block moving but another side getting stuck as you can see in the picture below. If this happens, moving the adjustment disc will not have any effect on the suspension. To resolve this, I dripped some soapy dishwater in the recess, and carefully pried the edges of the suspension block so the water could seep in.
