Size of slide shoulder washer for Q45 pivot clamp bolt?
Just shipped my bike from a bike shop, and they managed to lose the 2 washers that fit on the slide shoulder bolt of the pivot clamp as discussed from ~9:30-10:10 of the YouTube video for assembly of the Q45 (
). The inner diameter of this washer is 8 mm, but I just spent several hours at Ace Hardware and Lowes and was unable to find a replacement with an outer diameter small enough to fit into the recess on the pivot clamp. Anyone know the exact size of this washer and where I might be able to find a pair?
I.D. - 8mm
O.D - 11.8mm
Thickness - 1mm
The washers are the same ones that are typically used for MTB shock mounting sleeve bolts, so it is likely that a shop that works on/sells MTB's will have these. Not likely a typical hardware will have them.
