SOLD: 2021 Q45 for sale with extras...
rfneep
This bike is SOLD.. Thank you for your interest!
This bike was obtained new from Cruzbike in mid-February 2021. This is the same model as presently described on the Cruzbike website (www.cruxbike.com/products/q45)
This bike is essentially in its original condition, with a few minor improvements that are listed below. It has been used intermittently over the past 8 months, mainly for testing of the geometry and seat options to see how it works for me, including one ~90 mile trip on limestone trail. It is in showroom condition and ready to ride.
Bicycle specifications:
- Rear derailleur: SRAM NX Long Cage 11-speed
- Front derailleur: none
- Shifters: SRAM NX 1x11 Trigger
- Crankset: Driveline 155 mm cranks, 42T narrow-wide chainring, Chain guard
- Bottom Bracket: square taper 68mm 113mm width
- Cassette: SunRace 11-42 11-spd
- Brakes: TEKTRO MD-C550 mechanical discs; 160 mm front and rear rotors
- Brake Levers: TEKTRO Linear pull break lever with selectable pull ratio
- Handlebars: new Cruzbike Mountain handle bar
- Headset: Cane Creek ViscoSet
- Wheelset: 650b Jet Set rims with Chosen hubs
- Front & rear Tires: Maxxis Overdrive 650b x 1.65 in; less than 30 miles on each
- Chain: SRAM PC-1110
- Seat:: Cruzbike Q45 adjustable seat with variable seat angle
- Rear shock absorber: DNM Air Shock AO-38 RC
- Color: Neon Orange; near-perfect condition, but for: two marks on the front seat mount that are painted over and not visible when the seat is attached; small scratches on front right chain stay that are not very noticeable in normal lighting.
- Original documentation included
- Additions and/or changes from original specs:
- SunRace 11-42T cassette
- Rear shock absorber: DNM Air Shock AO-38 RC with lockout and rebound adjustment
- Pedals: Shimano Click’r PD-T421 (easy clip-in and clip-out; one side SPD, other side platform)
- Thru-axles: Robert Wood Project thru axles
- Installed rear fender bracket
- Detachable SKS rear fender
- Lizard Skins lockable hand grips - orange
- B&M cyclestar mirror
- Rear light mount stub on seatback
- Water bottle cage
- Trainer compatible front thru-axle
Included extra OEM parts:
- SRAM PG-1130 11-42T cassette
- Rear shock: KS EXA 290 external spring shock 165 mm, rated 1200 lbs/inch
- Thru axles: quick-release 12 mm thru axles
- OEM black handlebar grips
Bonus Offer: Bacchetta B3 seat with Q45 mounts
I have a Bacchetta B3 seat with mounts appropriate for the Q45 also available for sale. It provides a mesh seat back with good ventilation, plus alternate seat cushioning compared to the relatively hard aluminum OEM seat. This seat lists for $300 without the Q45 mounts, and are presently out of stock until next January. It has only been used for tests and is essentially in new condition. Will include a shorter rear seat stay for more range of recline angle than the OEM version. It can be included in the purchase of the bike for an additional $150 shipped.
Notes:
This bike can easily be converted to a hardshell/carbon seat such as a Volae or Thorseat if you want a more reclined seat angle.
Price is $1,900 if picked up locally, $2,000 plus shipping if packaged for shipping.
Bike is located in Madison, WI. As always, it is easier to not ship, so I am willing to drive a reasonable distance to meet a buyer if desired.
Ray
Left side.jpg Right view.jpgCockpit.jpg Rear view.jpg Air shock.jpg Extras.jpg B3 seat.jpg decked out.jpg
I am looking for this model for the Cruzbike Museum. I have sent you a PM
rfneep
Anything tweaked by @rfneep is too nice for the museum giving a false sense of stock due to perfectly executed improvements and immaculate care.
That's very nice of you to say, but c'mon I could scuff it up and remove any small improvements. Would look right at home! Ha!
Give it to me. I will drill holes in it, fix mudguards on with fence wire, put brake levers on upside-down, get it muddy so the scratches are invisible. Will that do?
2whluge
Good morning, Ray,
Still have the bike? I’m traveling through Madison tomorrow and I’m interested.
Best, Dennis
Good morning, Ray,
Best, Dennis
@2whluge with such a tight timeline you should probably put your cell phone number in a private conversation to @rfneep.
To send a direct message, click on rfneep’s avatar beside his post and select “Start a Conversation”.
@2whluge Great acquisition. Welcome to the Cruzbike family.
If you have any questions whatsoever do not hesitate but ask them on this forum. There is a wealth of info but it can be hard to find. If you haven’t already ridden a Cruzbike I suggest following the instructions from Cruzbike and on the Learning to ride thread on this forum.
https://forum.cruzbike.com/threads/spring-time-learning-to-ride-time.10889/
Happy Trails!
Ben.
2whluge
I picked up a Q559 this summer and liked it well enough to look for a Q45. And this one was within driving distance! Had it out today for the first extended ride. It needs some tweaking but I think it’s going to be a great ride!
