makinit1212
So I'm in! Glad to be a 451 V2 owner and excited to join The Tribe. I picked it up pretty quick and handled about 12 miles today without killing myself. Many thoughts on the ride, etc but first up, I have some basic questions.
I barely fit on this thing. (6ft.) Previous owner swapped out the shorter chainstay for a longer one because the BB was just too low for his liking with the stock one. Well my knees were hitting the gear shift, etc on the bars. So I raised everything as high as possible, including the adjustable stem that is on there and I barely make it. It's not enough clearance. I assume I can just put the shorter chainstay back on and get a little space but I like the idea of being closer to parallel with the ground like he did. I suppose I should try the stock one, but I suspect I am not the first person to have to figure out how to fit on this thing and I was thinking I can just get a taller riser. Where can I find one? Will I start affecting the stability and strength of the system if I go too tall with it?
This pivot clamp with the quick releases is going to rub my thighs raw. This seems like a bad design decision. Why quick release? Seems like even skinny legs would hit both sides as well, no? And what can I do to replace it with more traditional mounting hardware?
Wider bars. Because I'm new, and wobbly, seems like wider bars would go really far in helping me feel more stable as I work through this learning curve. Any recommendations or resources for those?
Thanks in advance for any help and feedback.
