Why specify no magnet?
If your streets are mostly smooth, you shouldn't need to worry.
If you're biking off-road over boulders and bears, then I can see that having no magnet
on the wheel would be a plus....
The bare-bones wired Cateye bike computer on the Sofrider is on its third battery, since 2006.
The magnet on the spoke has had to be readjusted NO times.
The wired Cateye bike computer, with cadence, mounted on the V last year is doing fine:
No further adjustments and I expect to change out the stock battery sometime next year.
The magnets on both the flattened flat-black spoke and crank arm have required exactly NO maintenance.
When dad died, he wasn't getting much use out of his Garmin GPS anymore... because being dead
kind of puts a damper on things. So, I made an adapter and put his GPS on my Sofrider.
Dad did not mind... I guess.
The Garmin worked fine for a few months, eating batteries like I could not believe.
Then, it died, under warranty.
The replacement worked for a few days and then it too died: Throwing it in the trash was fun!
I'm sure that GPS devices have improved over the last decade ... but the magic
acronym, "GPS" does nothing for me; it doesn't trump the utility of these cheap, reliable
little bike computers.
So what do you have against magnets anyway?
