nobrakes
I thought I would start this thread having been through the problem myself and seeing the same question come up again and again.
The problem: with compact doubles, it can be problematic getting the front mech close enough to the big ring for optimal operation.
In my case I have Sram Force 22 components with a 50/34 compact double. The front mech cannot get close enough to work optimally, as the yaw action requires the derailleur to be 1-2 mm from the big ring. Any further away and the slope of the derailleur cage as it ‘yaws’ makes shifting more difficult. The closest I can get is about 5-6 mm. I have spent hours and hours fiddling with it and studying YouTube videos on adjusting SRAM yaw derailleurs. The best I can get is ‘OK’ - with a bit of attention to your shifting technique it will change up reliably but if you don’t treat it really gently it can throw the chain. Back off all pressure and shift really fast is the way that works for me.
I believe this problem will manifest on any compact double with a front mech that has one central bolt hole. Older mechs that have 2 bolt holes to choose from are probably OK as you can get it closer to the chainring. I think Sram moved from 2 to 1 bolt hole design recently which is maybe why it hasn’t been addressed yet by Cruzbike.
The wickwerkz spacer does not work - it puts the front mech too close to the big ring. The place the front mech should be placed on a 50/34 with single bolt hole is right on the edge of the braze on mount where there’s no hole.
I imagine any front mech that does not have yaw action will be less affected by distance although I have not tested that so it’s just a hypothesis.
The ideal solution would be for Cruzbike to extend the braze on mount by another cm so there’s more adjustment available.
Other solutions - non yaw derailleur (untested by me), bigger chainring, or just put up with it and refine your shifting technique.
I do wish Cruzbike would put something on the site to stop people making the same mistake. I believe it’s the shift to single holes front mechs that is the root cause but it should be made clear that there can be issues depending on your front mech and big ring size.
I’d be interested to hear what other compact combos people are using and how well they work. Particularly if you have a yaw derailleur with a single bolt hole and a 50T or smaller big ring.
