The new 2021 - S40 Tames the Blue Ridge Parkway with class
On May 21-27, 2021 I had the honor of riding Crubike’s newest S40 on a week-long bike tour across the Skyline Drive and Blue Ridge Parkway. This was from Front Royal, VA to Cherokee, NC. In those 7 days I rode the new S40 over 700 miles and 70,000 feet of climbing and descending. Here are my comments and view-point on the new S40.
First - the 2021 Cruzbike S40 Stock setup:
  • Weight: S40 Complete 2021: 27.2 lbs
  • Cruzbike patented FWD-MBB technology (same as with all V20 and S40 in current production)
  • Cane Creek ViscoSet® Headset
  • Thru Axle - For the new thru-axle on the S40 uses a leverless style that even houses its own internal removal tool for the axle itself and brake rotors.
  • Wheels and tires: 32 spoke 3 cross black aluminum rims, aero profile, tubeless compatible, 25 mm wide rim, approx 28 mm depth non-machined sidewalls, Maxxis Re-Fuse 700x32c tires
  • 160mm MCX-2(PM) Mechanical Disc Brakes front and rear
  • Carbon FIber Seat (with small adjustable “S40”, seat extender flap for the front edge
  • Basic curved headrest
  • Thick foam seat pad
  • Standard Cruzbike flared handlebar set
  • SRAM 1x11 drivetrain utilizing 42 front ring and PowerGlide 11-42T 11-Speed Cassette
  • “Truvativ/SRAM Team GXP” Bottom Bracket
  • SRAM Apex 1 GXP Crankset 165mm with 42T 110mm Asymmetric BCD X-Sync Chainring
  • SRAM Apex 1 DoubleTap Right 11-Speed shifting Lever for Cable Actuated Brakes
What does the new S40 version give you over past models:
  1. Thru-hub wheel sets
  2. 1x11speed “” drivetrain
  3. Viscoth Headset
Jim and Maria Parker were generous enough to “loan” one of these beauties to myself and Ken Halzhausen to “test-ride” on our “7-day ride”.
I was initially quite excited and then a little apprehensive to ride something “new” on such a long and challenging. My biggest fear was to change from what I was so used to so drastically. I normally ride a V20 with a ventisit pad, 150mm cranks and midsole cleats. I first grabbed a new pair of shoes and installed the cleats at the toe again to hopefully give me a little more reach for the 165 mm cranks. Jim did give me the option of a ventist pad, but since everyone else had chosen the stock seat pad and it looked comfy I decided to go with “pure stock setup”.
After about an hour of setting the S40 up to fit me in the parking lot the night before I “thought” I was ready to embark on my 3rd crossing of this great tour.
I’ll have to admit the first 60 miles of the Skyline Drive was “not enjoyable” at all. My legs hurt, my arms hurt, my knees hurt, my neck hurt and I was getting hot-foot already. Gosh - I was almost dreading the next 640 miles! But after stopping a few times and re-adjusting the boom , the handlebars, and the headrest to fit me better, - all my problems suddenly vanished. We adjusted the boom so the Bottom Bracket was farther out so my knees were not bending too much, moved the handlebars a little farther away so my arms were comfortable, and adjusted the headrest some so my neck and head were in a better position. Amazing what a correctly fit bike will do for your ride, body, and your attitude. Even better than that - I felt re-energized and felt I could make power better. That is usually the case when there is no pain!
I am telling you all this as proof that bike fit is “so important” - just a few inches one way or the other in several key areas can make a great bike feel like it is not for you. If you feel like this with your current Cruzbike, then I urge you to ask someone for help. Post your pics on the forum and someone will help you. If you can make it down to Hilton Head Island - I will personally assist you with your fit and have you riding “and loving” your Cruzbike like never before.
Ok back to the S40 critique:
In my opinion this is by far the greatest iteration of the S40 design.
While my bike of choice for pure speed is the V20, the S40 shines in a 7-day tour like this.
The higher seat angle allows you to see all the beautiful sites better and actually helps “slow” you down on some of the scarier descents. It is also a well known fact that a higher seat angle allows better power making capability which is sometimes a blessing on those 2 hour climbs.
Thru-hub axle design:
The new thru-hub axle design gives the front end a more solid-tight feel and you feel like every watt of power applied to the pedals is going straight to the front wheel! This is probably the greatest improvement in this interaction of the S40.
Viscoset headset:
Another great improvement that is basically a dampener for the front end
The front end never feels like it wants to flop one way or the other and I never noticed any shaking or awkwardness when going downhill at 40+ mph, or uphill at 4!
1x11 drivetrain:
This 3rd improvement or “change” in the newest S40 setup I was most skeptical about.
This was partly because of the heart attack and stent I had placed in my chest 3 months earlier and the doctors orders that I should not exceed 120 bpm while riding. I just did not think the 42 tooth front ring and the max 42 tooth large ring on the cassette was going to be good enough for the long, long, long 6-7-8% grades that we were going to be asked to ride on this tour. And not just for a few minutes or miles, but at times nearly 2 hours non-stop.
Well, I was pleasantly surprised to discover that the 42x42 was perfect for those extended grades and even with my lower required power output of 2 W/kg. I found I could go up a 6% grade at about 4-5mph on those 2 W/Kg and still keep my balance and also keep my heart under the 120 bpm. Hallelujah!
In my opinion Cruzbike hit a home run on this newly designed S40!
And I was so lucky to be given a chance to buy one of these first ones at the end of the tour - Thanks Jim & Maria for that opportunity!
I understand that they are pre selling these new S40s right now and they should be available for delivery sometime in late June or early July. From what I understand there are only 150 of these babies to be had, so if you want one I would put your order in now. Who knows when the next set will be available?
R-Jd2anwA7TnwEElQ4y-Iu-K_U70m2Y1U8KslszTEah0BgMHgAnGdTH_w4TcyMve72F2Dn2iTEQSNyuszi8KA-af4Ps-9UzrFeOBQb-jwyjv7ccejMLupjYh7JRbJ_arCKhbastR
mQwZDMAKhEPMJINeNDlJA_4JyCHGcP_9uCTlpx7TrHNgx0pO4C7S6i7PCmhboAYZzrLcQxcR0G5kOb08-Opc2DydRTtQ43J8jW0jpttrx6fC-kp7rLbPmxIEzhtD0sppGESfKybp
txznlEcmZRUYPiAxXZU6OFr5HOYc2f9vRJ4yJtsYrRenBgl5unxd1SsvY3b0lJA34mo-4qlG8XL2gaycAgKWicV3ss9PmRYzqW-CPjPSSU9EEhnR09NCTIm8s5FG-Li1yVATGvle
@LarryOz As someone who now has hundreds of kms of experience with both the ventisit seat pad can you give a comparison including which version of the ventisit you use, warmth, comfort, breathability, how well they each stay in location on the seat, etc. And if you have used the old two piece seat pads of the early T50, Q, Sofrider, Conversion kit bikes that would be a great help.
Unfortunately I don't have a huge perspective on different ventist pads. I think I bought the "thick" one when I got my first Vendetta - and have probably been using it ever since.
My only experience with the "old 2 piece" pads where the ones that first came with the orig Silvios & Vendettas (I had several sets in a box somewhere) I did not like the 2 piece primarily because the bottom would come off easily. I also liked the way the ventist breathed and allowed all my sweat to run through it and evaporate.
I was however quite pleased with the one-piece pad that came with the new S40. It was very comfy and stayed in place nicely
Larry
I am getting the new S40 frameset on Tuesday. New to Cruzbike. How did you mount the bottle cage?
Congrats!!
There should be a couple of holes to receive the water bottle cage on the "slider" portion. You may have to rotate the slider to position them so you can mount it as I have shown. Some people don't have room because of the angle of the boom/slider, if that is the case, then you point them up and either mount the bottle on the top, or not there at all. Some people mount under the seat to the left or right, or mount a race case or cage mount system behind the headrest.
Good luck with the new S40 - it is a beautiful bike and piece of machinery all in one.
Dave Millhisler
Congrats!!
Good luck with the new S40 - it is a beautiful bike and piece of machinery all in one.[/QUOT
Did I read somewhere that you had the tire pressure at 60 psi on the Blue Ridge Parkway ride?
I think that is correct - You might have read that in Jim Parker's review- I do not think I mentioned anything about tire pressure in mine
Thanks for info.
I regularly run 32 mm conti gps tubed at 50 psi by my track pump. Super comfy. On the pelso brevet but would be as nice on the silvio. Better weight distribution on the cruzbike. And congratulations.
