Trim
Robert Stewart
Hi all,
I have been having a few issues with the ends of the Silvio trim (aka rubber protection strips for seat flange edge) coming loose and flapping around (e.g. a high speed descent yesterday dislodged about 10cm of trim from the bottom left of the back piece). Has anyone else had this problem? Can I glue the ends down, and if so what glue should I use?
Rob
defjack
Use a small amount of Plumbers Goop It works great.I ran a thin bead on the inside of strip problem solved. Jack
A friend of mine suggested automotive trim adhesive called sticky tack, I think. He said they used to use that back in the day for sew up tires.
