bazzawill
So I have always had an issue centering my rear disc brake but never had a problem with the front. This may have got worse since changing the pads to TruckerCo Metalic pads. It got to the point where I removed the rotor from my wheel and went for a test ride and noticed a significant reduction in friction.
I have since come to realise the rear rotor (Avid HSX Disc Brake Rotor 140mm) may be slightly thicker than the front (Shimano SM-RT30 160mm).
I don't think that it is possible to widen the pads rest position, so it looks like I need a new rotor. TRP and others make 140mm rotors that may be compatible but they are more expensive at A$40-60 and I can't be certain of their thickness. I will most likely pick up another Shimano SM-RT30 160mm as I am not racing for sheep stations I just like to go fast. Has anybody else come across this?
