Upgraded QX100 rear shock.
Crog Welly
New K1 Air RR1 on my QX100.
7F7E96A8-B0D5-4614-913A-E6FDD1A5D461.jpeg F85273A8-00C7-45E0-8BF3-76A290EDB8BF.jpeg
Had to move one of the rack mounts and also add spacers to the rear fender anchor.
First ride impressions are that it’s very quiet; less bouncy than the stock and smoother over all sizes of bumps and pot holes.
I weigh 210 and have the mp set 150 and the np set at 125.
Scott
How has your air shock performed over time?
Any maintenance requirements/issues?
I have a QX100 and I am thinking of doing this also.
Scott
Not so far. Maybe I’ll check the pressure one of these days but it hasn’t lost enough to notice.
augiedog
Do you have a part number,size and where you purchased your shock? When I search K1 Air RR1 I get a KS A5 RR-1 is this the same shock?
billyk
Yes. A5 RR-1
There’s been a ton of discussion of this in this forum. Unfortunately you can’t use the forum search (gives the word-too-common error, possibly not with quotes). But search Google for Cruzbike A5 RR-1 and you’ll find them. All the info you need.
It’s been while since I had an older Q, but I think that one took a 125mm shock, which is less common. The Q45 takes 165mm.
I ordered both of mine from a Chinese company I’d never heard of, with half an idea that I’d lost $75, but it arrived in the mail in about 3 weeks.
Definitely get one! It's a big improvement!
castlerobber
I may have an A5-RE in my parts box, 125mm for the Quest and QX100. It's also an air shock. but has only one inlet. I'll check and let you know.
I have an A5-RR1 on my Q. Honestly can't tell much difference. Both are much better than the stock shock.
I have to tell on myself, though. The A5-RE had been doing great, and then it went flat and wouldn't hold air. After multiple attempts, I gave up and ordered the RR1. Only after it was too late to cancel the order did I think to check the valve core...and sure enough, it was loose. :oops: The RE held air fine after I tightened it.
